Tautomer
Newbie
Hello.
I am trying to build a circuit, where a single LED is blinking with a specific frequency (using breadboard). Is there a timer I could use, where the output frequency can be changed within a program?
Example: LED is blinking 100 times per second. By the press of a button, I want to change that to 60 times per second (and many other different values). If I used the 555 timer, I would have to fixly set the frequency while building the whole circuit (or using potentiometer).
