adjustable sawtooth genarator circuit
vinothtnt
Junior Member level 1
need circuit diagram
i need circuit diagram for adjustable sawtooth genarator circuit
Re: need circuit diagram
See here
Hey I realize that this is an old post -- any way to do this with only a +5 V power supply?
It should work. The only thing using the -5V is the first opamp so as long as you pick one that works down to ground it should be ok. The input will never need to be zero volts as that would give zero discharge current anyway.
Keith.
Sounds good. Guys what would you recommend using as far as software goes for simulating a configuration such as this? I use ADS for RF block level simulation but it would be overkill for something like this, no?
T
Download the free demo software from SIMetrix.co.uk. It is only limited by circuit size.
Keith
