speedfeak
Newbie level 1
Hello,
I'm looking to replace my current central heating boiler remote control (it's not really a thermostat) (Viessmann WS in combination with Viessmann Trimatik MC) with an Arduino. This remote control is in my living room and tells the boiler which temperature I want for day and night settings. It does that by changing the resistor value between three cables: one ground and one for day temperature and one for night temperature. There's 24V (according to the manual both AC and DC, I assume this is because there are more expensive remote controls that allow you change more settings) on those wires. The resistors can be set as follows:
- night 287 to 317 Ohm = 7 to 23°C
- day: 290 to 318 Ohm = 14 to 26°C
The wires need to be 1.5mm2 according to the manual
My question is: how can I incorporate this in an Arduino? I can't use digital potentiometers directly on the wires due to the high voltage and currents. If I place them in parallel with a resistor, I assume I need to measure the current in order to keep the total resistance at the desired level? Or is there another, more straight forward way?
Thanks in advance!
Pictures:
Thanks in advance!
Pictures:
