eigenroot
Junior Member level 3
Hi everyone,
I am trying to measure the long tail photocurrent decay of a photodiode with a current amplifier, but the initial part of the decay which I am not interested is giving me trouble since it can easily overload the amplifier or oscilloscope if I crank up the amplifier gain (the original discussion is at https://www.edaboard.com/threads/264508/). Originally I used an anlog switch to filter out the part I don't want, but the charge injection introduces a new disturbance.
Someone suggest me use a limiter, which passes all current below a certain value \[I_0\]but floors any current greater than \[I_0\] to \[I_0\]. However, after a quick search, most RF limiters are voltage limiters, and the voltage cap is determined by the diode turn-on voltage which is not a very adjustable parameter. Is there an adjustable current limiter I can use? Adjustable voltage limiter is also okay although I prefer current limiter.
Thanks.
Thanks.
