ADE7878 Low & High (42.5 & 52.5) range Frequency issue
panneerrajan
Member level 1
Member level 1
Trivandrum
We were using ADE7878 for three phase meter application.
Meter working fine in 50Hz frequency. But at low & high range levels facing out of accuracy.
Please provide your suggstion
Thank you,
Rajan
1) read the datasheet
2) explain what "facing out of accuracy" means. It doesn't tell anything to us. Give values with units.
Klaus
Klaus
Thank you for your support,
While testing energy(kWh) in low & high level frequency input. Energy accuracy should maintain ±0.8.
But accuracy value going out of range
Thanks
Rajan
Where do you find the informations in the datasheet?
* 0.8
* 42.5
* 52.5
(--> Always give values with units)
Is your test circuit and the test signals exactely the same as in the datasheeet?
Klaus
