Deepak Rathore
Member level 2
hello friends,
I have one major doubt about the ADE7763 that i need to be clear instantly.
i ideally when v r not giving any input on the Voltage channel 2, then our Vrms Register reading should be zero.
but in my hardware i m getting some value in the Vrms register so i check my hardware. when v r not giving any input on the Voltage channel 2 , then there r minor mV signal (0.006) is present that is negligible so i need to correct this problem with firmware. i have made all the configuration same as that is specified in the datasheet.
so what should i do to correct this.
Deepak
Deepak
