gandhig
Newbie level 2
is it possible to find the address decoding logic of a 2 mbits flash memory (256K x 8) which is used as bios rom from its datasheet? the flash memory is divided into 5 blocks of 128 KB, 96 KB, 8 KB, 8 KB & 16 KB. it is written as compatible with standard microprocessor interface and JEDEC flash compatible pin out. i want to know which address pins will be used for the top 128 KB block and the bottom 16 KB block. can someone guide me?
regards,
g.gandhi
regards,
g.gandhi
