Alipoursaadaty
Member level 3
Hello,
I have designed a wideband ultra-low noise high gain amplifier with a voltage gain higher than 80 dB, input referred noise less than 1 (nV/sqrtHz), and a BW higher than 250 MHz. However, it is oscillating in higher gain, and I have to reduce the gain to achieve some measurement results.
In 60 and 70 dB voltage gain, it is near to oscillation, and when I want to apply a sine wave with 0 dBm and 10 MHz specifications, I can see the amplified output signal. However, other spectrum frequencies are appearing. The range of these frequencies starts from the 3-dB BW of the amplifier like 400 MHz and this frequency interval is higher than 100 MHz. Also, some other frequencies like 1 GHz can be seen in the spectrum analyzer. I tried to change the sine wave generator and used another one to make sure if these frequencies were produced by the generator or not. However, the problem was not solved.
Does anyone know how I can solve this problem?
I must mention that when I turn the signal generator off (no input signal), these frequencies disappear.
Regards,
Regards,
