jerryt
Junior Member level 3
Using IEEE packages:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.ALL;
I want to add two numbers of bit length 8 and store the result into as an output of bit length 16. I am getting the following error when trying to compile my design:
# ** Error: D:/Profiles/w30239/My Documents/Miscallaneous/ECE 584/Project/Comp Instantiation Example/GoertzelAlg.vhd(33): (vcom-1272) Length of expected is 16; length of actual is 8.
How do I fix this error if I want to make sure my output (Xk0) is 16 bits but my inputs (x0,x1) coming in are 8 bits?
Thanks for your help!
Here is a snapshot of my code:
entity GoertzelAlg is
Port (x0,x1 : IN signed (7 downto 0);
Xk0 : OUT signed (15 downto 0));
end GoertzelAlg;
architecture Structure of GoertzelAlg is
begin
Xk0 <= x0+x1;
end Structure;
library IEEE;
end GoertzelAlg;
begin
Xk0 <= x0+x1;
end Structure;
