engr_joni_ee
Advanced Member level 3
I forget to add protection diode in the PCB for someone who mistake reverse the power supply cables. The current consumption in the PCB is around 2.6 A at 12 V. I am wondering if I add 1N5402 in reverse bias, would it serve the purpose ? i.e., in normal operation if the power supply connection is correct the diode will be reverse bias and if the power supply connection is wrong the the diode will be forward bias to protect the rest of the electronics.
