Adding another pair of VDD and VSS in ICC2
NeilDegruth
Hello,
I'm using ICC2 in my project and I want to add more VDD and VSS ports for the same power mesh. I've tried adding new power ports in UPF but didn't work and couldn't find a solution for my case in Synopsys Solvnet? What should I do?
Solution
you have to calculate how much power it draws and how to size the *entire* power grid accordingly. there is no notion of IO cell ratio to block size, generally. the power grid is likely shared between many blocks unless you have individual power islands.
Solution
LaTeX Commands Quick-Menu:
