bzblues
Hello everyone!
I have this guitar amplifier that I've added a tremolo circuit. I manage to add a DPDT switch to select between the clean signal (goes straight to the amp circuit) or the tremolo circuit (goes to the tremolo and then to the amp)
So, there is a way of replacing the DPDT switch for a female 1/4 inch jack that I can connect a footswitch to turn on and off the tremolo circuit ... or to select between the clean guitar signal and the signal with tremolo. I've been researching but is a bit confusing.
What would you guys recommend?
Thank you!
Thank you!
