[SOLVED] Adding '1' to a std_logic_vector in VHDL
chandlerbing65nm
Member level 5
Member level 5
I'm having an error about adding 1 to a std_logic_vector in VHDl.
Here's the code: It's a 74LS163 Synchronous Binary Counter code.
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
entity AAC2M2P1 is port (
   CP: 	in std_logic; 	-- clock
   SR:  in std_logic;  -- Active low, synchronous reset
   P:    in std_logic_vector(3 downto 0);  -- Parallel input
   PE:   in std_logic;  -- Parallel Enable (Load)
   CEP: in std_logic;  -- Count enable parallel input
   CET:  in std_logic; -- Count enable trickle input
   Q:   out std_logic_vector(3 downto 0);
    TC:  out std_logic  -- Terminal Count
end AAC2M2P1;
architecture LS163 of AAC2M2P1 is
signal temp: std_logic_vector(0 to 3);
signal RCO: std_logic;
	begin process(CP, SR, PE)
		begin
			if 	(SR = '1') then
			temp <= "0000";
			elsif (rising_edge(CP)) then
				if (PE = '0') then
					temp <= P;
					if (temp = "1111") then
					temp <= "0000";
					RCO <= '1';
					else
					temp <= temp + 1;  --ERROR
					RCO <= '0';
					end if;
				end if;
			end if;
		end process;
	Q <= temp;
	TC <= RCO;
	end LS163;
I used 1076-2008 in ModelSim - Altera, as "temp <= temp + 1" should be synthesizable but it still got an error when simulated -- No feasible entries for inflix operator '+'.
I tried using x"1", x"0001" and '1' but all of these didn't worked.
Also, how should I write the code for using CEP and CET as count enables.
adding std_logic_vectors is not supported in the numeric_std library as fourtytwo suggests use unsigned which does support arithmetic operations.
Code VHDL - [expand]
8
process(clk)
begin
  if rising_edge(clk) then
    if (CEP = '1') then   -- counts when high
      CEP_enabled_counter <= CEP_enabled_counter + 1;
    end if;
  end if;
end process;
Or use VHDL 2008. The numeric_std_unsigned package allows unsigned arithmatic on std_logic_vector, even allowing the perenial student compilation error - adding a std_logic to a std_logic_vector
8
9
10
use ieee.numeric_std_unsigned.all;
signal cnt : std_logic_vector(15 downto 0);
process(clk)
begin
  if rising_edge(clk)
    cnt <= cnt + '1';
  end if;
end process;
I got this final code:
signal temp: unsigned(3 downto 0);
signal count_enables: std_logic;
	begin
	count_enables <= CEP and CET;
		process(CP, SR, PE, P) begin
			if 	(SR = '0') then
			temp <= "0000";
				if (PE = '1') then
					temp <= unsigned(P);
					if count_enables = '1' then
						RCO <= '1';
						temp <= "0000";
						else
						RCO <= '0';
						temp <= temp + 1;
						end if;
					end if;
				end if;
			end if;
		end process;
	Q <= std_logic_vector(temp);
	TC <= RCO;
	end LS163;
and this is the waveform from ModelSim - Altera:
But the auto grader scored it 5/10 (at online course), (It count up until F for a given time period though). It must be that some of the functions of 74LS163 is not used or misused. If someone could look ever what I'm missing, that will be helpful. Thanks
The TC output is wrong, should be '1' when the counter is "1111" and CET = '1'.
The parallel load is wrong, should happen when PE = '0', regardless of CEP and CET.
An unsigned signal will wrap automatically from "1111" to "0000", so you don't need code for that.
I got the right answer with 1 error in TC. Scored 9/10 but still curious what is the error in TC.
Here's the updated code.
	begin
		counter: process(CP) begin
			if 	rising_edge(CP) then
				if SR = '0' then
				temp <= "0000";
				elsif SR = '1' and PE = '0' then
				elsif SR = '1' and PE = '1' and count_enables = '1' then
				temp <= temp + 1;
				end if;
			end if;
		end process counter;
		carry: process(P, CET) begin
			if CET = '1' then
				RCO <= P(0) and P(1) and P(2) and P(3);
			else
				RCO <= '0';
			end if;
		end process carry;
		TC <= RCO;
	end LS163;
Here's the waveform in ModelSim.
Since it is observing change in CET, P should be replaced by temp
carry: process(temp, CET) begin
if CET = '1' then
RCO <= temp(0) and temp(1) and temp(2) and temp(3);
else
RCO <= '0';
end if;
end process carry;
