osbourne
Member level 2
is it better to use a simple "+" in VHDL coding to synthesize an adder or shall I use the available IP core for adders ? What is the difference ? It is more convenient to simply write "+" when adding several signal busses. When using the IP core component, I have to write more code lines. On the other side, the IP core may be optimized by Xilinx. Is this correct ?
Which one should I use ?
Regards,
Osbourne
Regards,
Osbourne
