[SOLVED] add stripes/ring cadence soc encounter
conmourtz
Member level 1
Member level 1
Volos, Greece
Hello, i have a problem with my design on soc encounter. i need to add stripes/power rings and i want to know which soace and width the wires should have. i am working on 700nm lib with 5mm^2 area and about 12500 cells. How many stripes are needed for a design like that and how i can calculate the width, spacing and the number of stripes at any design?
hai friend
you can refer this document , i hope this might help you
when you synthesis your design you will get the total power required your total no of cells
thank u
  • Power Planning.doc
