danny davis
Banned
Add mode & Subtract and invert mode on the oscilloscope, Time base variable vernier
The Add mode on the oscilloscope is used when a circuit has multiple channels , so you use the ADD mode to ADD the 2 channels when troubleshooting a circuit that has different channels
But How does the ADD mode help you troubleshoot circuit's that has different channels with the same waveforms or with different waveforms?
When you do you use the Invert mode?
Analog O-scopes on a time base, has a Variable Vernier detent knob, if you click the detent out of calibrate position it puts the time base in a recurrent time base that is not calibrated they say
So what is the time base variable vernier knob used for?
