d123
Advanced Member level 5
Hi!
Could somebody tell me what mistakes I may have made in the layout (and possibly reasoning/understanding, especially of the OpAmp) for this circuit please? I've omitted external components for both ICs which would clutter the schematic and are not an issue.
The 0.01 Ohm resistor and trimpot are just an idea (maybe a bad one?) which may not be included, just in case when bread-boarding I see the ammeter is too inaccurate and needs tuning.
The current shunt monitor is an INAID286 current to voltage device (100V/V), the ADC is a TC7107 (don't tell KlausST!), the DPDT switch is a break-before-make rotary switch. The purpose of the voltmeter and ammeter is to monitor V and I on a power supply.
I understand that for a 200mV ADC scale, the shunt should also manage 0 - 200mV, so the INA286 will output from 0 to 20V (which the voltmeter divider of 1M/10K will reduce back to 0 - 200mV again).
I have some doubts (besides not being sure I've understood the range I'll get from the current shunt monitor OpAmp I selected for this purpose): Would it be better to have separate devices for each function/Will this set-up introduce further inaccuracy on what will obviously be a not very good homemade power supply, voltmeter, and ammeter? The voltmeter is at worst 15mV out compared to a multimeter, so I'd like to maintain that "accuracy", rather than lose it by cobbling an ammeter onto its input.
Thanks.
...I put a fuse in the wrong place and omitted another, so this is the corrected schematic.
Thanks.
