ADC reference voltage - some questions
Vitamin-C
Member level 2
Member level 2
HI,
Please see the graph.
It is a ADC inside a IC.
what is the purpose of putting a resistor 4k ohm
instead of biasing the ADC directly.
thx
Vita :)
Hi. This resistor is used if you want to connect external reference to adc(more precision reference than internal).
Best Regards.
Re: ADC reference voltage
Hi....
This conection seems a bias wire for ADC. I mean, you put a 4k resistance in order to limit the flow current toward ADC. If there is a little flow of current, you may find almost same 2.5 V biasing ADC.
the 4Kohm resistor has 2 reasons:
1. it's the reason described by petarpav.
2. if you use internal ref, the 4Kohm resistor and external cap (common 100nF), make the noise rejection of internal refference. (work as RC integrator)
Hi. I think the resistor is connected to external reference voltage. The voltage is used to ADC converting.
