ADC on PIC18F4520 using c programming
gordon the light
Hi, I'm new in programming. I need help in C programming using ADC in PIC18F4520.
First, i will be using channel 0 and I set RA0 as input which is a temperature sensor, LM351. Then the output will be connected to RC2 as buzzer. So i want the buzzer sound when the temperature reach a certain value.
Second, channel 1 will be use and i set RA1 as input, which is a trimmer. The output will be connected to RE1 which is a light bulb. So i want the trimmer to control the brightness of the light bulb.
So the question is, how to interface the channels according to the user choice? Help will be much appreciated. This is my code.
#include <p18f4520.h>
unsigned char result;
void sensor (void);
void light (void);
void main()
TRISA=0b00000011;      //pin AN0/RA0 & AN1/RA1 as input(fire sensor & trimmer)
TRISC=0b11111011;     // RC2 as output(buzzer)
TRISE=0;              // RE1 as output(light bulb)
ADCON2=0b00011100;   // result left justified, 6TAD, fosc/4
light();
sensor();
void light()
ADCON0=0b00000101;    // analog channel 1 is used
ADCON1=0b00001101;    // AN0 & (AN1), internal voltage reference.
while(1)
ADCON0bits.GO=1;              // start ADC
 while(ADCON0bits.DONE);      // ADC completed?
result=ADRESH;                   // store the high byte of result in A
PORTE=result;
if (result <50)
                    // Pwm program
CCPR1L=0b00001100;
CCP1CON=0b00101100;//20% duty cycle, frequency 1000Hz
else if ( result < 100)
               // Pwm program
CCPR1L=0b00011001;
CCP1CON=0b00001100;	//40% duty cycle, frequency 1000Hz
 else if ( result < 150)
                   // Pwm program
CCPR1L=0b00100101;
CCP1CON=0b00101100;	//60% duty cycle, frequency 1000Hz
 else if  ( result <200)
                // Pwm program
CCPR1L=0b00110010;
CCP1CON=0b00001100;	//80% duty cycle, frequency 1000Hz
 else if (result<250)
                     // Pwm program
CCPR1L=0b00111110;
CCP1CON=0b00101100;
	//100% duty cycle, frequency 1000Hz
void sensor()
ADCON0=0b00000001;    // analog channel 0 is used
ADCON1=0b00001110;    // AN0, internal voltage reference.
while(1)
ADCON0bits.GO=1;          //start ADC
while(ADCON0bits.DONE);   //ADC completed?
result=ADRESH;
if(result>10)
PORTC=result;
else
PORTC=0;
Use CODE tags when posting your code
you have some syntax and logic errors i observe.
1. in void light the while will never exit it will just sample show the result on portE so you need make the while loop to include your test conditions.
2.in c language the syntax for if else if is
if(condition)
{//your code
else if(condition)
{//your code
else if(condition)
{//your code
else
//your code
I hope this will help!
Use CODE tags when posting your code.
if (result <50)
// Pwm program
CCPR1L=0b00001100;
// Pwm program
CCPR1L=0b00011001;
// Pwm program
CCPR1L=0b00100101;
Just having had a quick look I dont think this section on code will behave how you think it will. If result is equal to 120 say your code will run through:
if (result <50)
// Pwm program
CCPR1L=0b00001100;
but not through the conditions such as <100 or <150 because C evaluates the first correct condition in and if/else statement only and ignores the rest, you would need to use a statement such as
         if(result <50) {
         else if(result > 50 && result < 100){
But as ahem0307 said you are going to be constantly stuck in the while(1) loop as the condition for that while loop, i.e the (1) is always true.
Pete
