[SOLVED] ADC not working PIC32MX795F512L MPLAB X IDE v5.20
farazahmed8
Newbie
Newbie level 3
I am trying to take ADC reading from two current sensors and two thermistors. But the ADC buffer always returns zero. Is there something wrong with the code?
// PIC32MX795F512L Configuration Bit Settings
// 'C' source line config statements
// DEVCFG3
#pragma config USERID = 0xFFFF // Enter Hexadecimal value (Enter Hexadecimal value)
#pragma config FSRSSEL = PRIORITY_7 // SRS Select (SRS Priority 7)
#pragma config FMIIEN = ON // Ethernet RMII/MII Enable (MII Enabled)
#pragma config FETHIO = ON // Ethernet I/O Pin Select (Default Ethernet I/O)
#pragma config FCANIO = ON // CAN I/O Pin Select (Default CAN I/O)
#pragma config FUSBIDIO = ON // USB USID Selection (Controlled by the USB Module)
#pragma config FVBUSONIO = ON // USB VBUS ON Selection (Controlled by USB Module)
// DEVCFG2
#pragma config FPLLIDIV = DIV_2 // PLL Input Divider (2x Divider)
#pragma config FPLLMUL = MUL_20 // PLL Multiplier (20x Multiplier)
#pragma config UPLLIDIV = DIV_12 // USB PLL Input Divider (12x Divider)
#pragma config UPLLEN = OFF // USB PLL Enable (Disabled and Bypassed)
#pragma config FPLLODIV = DIV_4 // System PLL Output Clock Divider (PLL Divide by 4)
// DEVCFG1
#pragma config FNOSC = FRCPLL // Oscillator Selection Bits (Fast RC Osc with PLL)
#pragma config FSOSCEN = OFF // Secondary Oscillator Enable (Disabled)
#pragma config IESO = OFF // Internal/External Switch Over (Disabled)
#pragma config POSCMOD = OFF // Primary Oscillator Configuration (Primary osc disabled)
#pragma config OSCIOFNC = OFF // CLKO Output Signal Active on the OSCO Pin (Disabled)
#pragma config FPBDIV = DIV_1 // Peripheral Clock Divisor (Pb_Clk is Sys_Clk/1)
#pragma config FCKSM = CSDCMD // Clock Switching and Monitor Selection (Clock Switch Disable, FSCM Disabled)
#pragma config WDTPS = PS1048576 // Watchdog Timer Postscaler (1:1048576)
#pragma config FWDTEN = OFF // Watchdog Timer Enable (WDT Disabled (SWDTEN Bit Controls))
// DEVCFG0
#pragma config DEBUG = OFF // Background Debugger Enable (Debugger is disabled)
#pragma config ICESEL = ICS_PGx1 // ICE/ICD Comm Channel Select (ICE EMUC1/EMUD1 pins shared with PGC1/PGD1)
#pragma config PWP = OFF // Program Flash Write Protect (Disable)
#pragma config BWP = OFF // Boot Flash Write Protect bit (Protection Disabled)
#pragma config CP = OFF // Code Protect (Protection Disabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#include<string.h>
#include<stdio.h>
#include<stdlib.h>
#include<math.h>
#include<plib.h>
void initADC(void);
int ReadADC(int ch);
void delay_ms (WORD delay);
int main()
initADC();
unsigned int channel0;// conversion result as read from result buffer
unsigned int channel1;// conversion result as read from result buffer
unsigned int channel2;// conversion result as read from result buffer
unsigned int channel3;// conversion result as read from result buffer
while(1)
channel0=ReadADC(0);
delay_ms(0.5);
channel0=ReadADC(1);
delay_ms(0.5);
channel0=ReadADC(2);
delay_ms(0.5);
channel0=ReadADC(3);
delay_ms(0.5);
void initADC(void)
AD1PCFGbits.PCFG0 = 0; // Analog input in Analog mode
AD1PCFGbits.PCFG1 = 0;
AD1PCFGbits.PCFG2=0;
AD1PCFGbits.PCFG3=0;
AD1PCFGbits.PCFG4=0;
TRISBbits.TRISB6 = 1; // Pin set as input
TRISBbits.TRISB7 = 1;
TRISBbits.TRISB2=1;
TRISBbits.TRISB3=1;
TRISBbits.TRISB4=1;
AD1CHSbits.CH0NA = 0; // Channel 0 negative input is VR-
AD1CHSbits.CH0SA = 0; // Channel 0 positive input is AN0
AD1CON1bits.FORM = 0; // Integer 16-bit output
AD1CON1bits.SSRC = 0b111; // Internal counter ends sampling and starts conversion
AD1CSSL = 0; // No scanning required
AD1CON2bits.VCFG = 0; // Internal voltage references
AD1CON2bits.CSCNA = 0; // Do not scan inputs
AD1CON2bits.BUFM = 0; // Buffer configured as one 16-word buffer
AD1CON2bits.ALTS = 0; // Always use MUX A input multiplexer settings
AD1CON3bits.ADRC = 0; // Clock derived from PBclock
AD1CON3bits.ADCS = 0b00111111; // TAD
AD1CON3bits.SAMC = 0b11111; // 31 TAD auto-sample time
AD1CON1bits.ON = 1; // A/D converter module is operating
int ReadADC(int ch)
AD1CHSbits.CH0SA = ch; // Select input channel
AD1CON1bits.SAMP = 1; // Start sampling
while(!AD1CON1bits.DONE); // Wait for conversion to complete
return ADC1BUF0; // Read conversion result
maybe the ADC inputs are at 0V, then be happy when the result is 0.
Klaus
I have tested it with oscilloscope, there is voltages present at the ADC pins.
I don´t doubt this.
the question is: what voltage?
0V is a voltage and it will result in output 0
-0.5V is a voltage and it will result in output 0
+0.005V is a voltage and it may result in output 0
...and if you have a known input value you may define what output value (range) to expect.
Klaus
The voltage is varying from 1.43 to 1.74V
informations come piece by piece....
I can´t know what output value (range) to expect.....
I just can assume not 0 ...
Does the ReadADC() return at all?
How do you know they are zero? Can´t find in your code..
What about VRef?
What about clock setup?
Please try to give complete informations in one post.
Klaus
Hi KlausST, It was hardware issue and the problem is resolved now, ADCs are working fine. The answer to your question about the zero, i was sending data that i read from the ADCBUF0 to the Uart and read it through hterm.
