[ARM] ADC Measurement NAU7802
satyagp
Newbie level 2
Hi
I want to measure the 4-20mA current.i CONVERTED current to to voltage convertion for my measurement.I am Using NAU7802ADC and Connected as mentioned in Application Circut in Datasheet with single Ended mode.
AVDD=3.3V
VREFP=3.3V and VREFN=0V
Internal RC Osc used.
My Probem
A) I was unable to measure full range.i.e..0-3.3V range.
I am getting range 0--1.675V with digital Output maximum is 000000-7FFFFF ONLY.
B) While measuring input there is a 32mV error.
please help me how to resolve it? Am doing correct or not?.I want to nullyfy the error.
Note : Please see my attachment schematic and Pictures.
Check your initialization code.
Thanks for reply.Now I am getting 7 mV error after activatin PGA option.
Why am getting 1.65V=ADC count0x7FFFFF?Its the half of the count only.As per Datasheet in Functional Description mentioned that in single Ended mode will get Full scale rrange for half of the VREF.How can I use this ADC perfectly with 24Bit resolution in my application.My application is measure DC Voltage is 0-1.5v Max.
