saidutt
Member level 2
hi friends,
I am interfacing ADC with temperature sensor(LM35) and micro-controller.
the output (voltage) values of ADC is Hex values which is voltage values of LM35.
if voltage at LM35 output is 2.4 volts and the ADC will give you hex value of 2 volts only.it will omit 0.4 volts.if i want to display 2.4 Volts on to the hyper terminal.
voltage at LM35 output from 2.1 volts to 2.9 Volts and the ADC will give you hex value of 2 volts only.
so how do get that value?please help me out figure it out
