ADC Interfacing : 8051 and MCP3202
karan123
Member level 3
Member level 3
Hello,
I am using "ADC0804 with Optocoupler" and 8051 for measuring Analog Voltage.
Now I want to use MCP3202 which is SPI Protocol Based, Becasue is required
Less pins to interface with 8051 Microcontroller.
I have read from datasheet that It required “Anti-Aliasing Analog"
which is MCP601".
My Question is that How I know MCP601 is require for me or not??
Thanks in Advance.
Karan
karan123 said:
Hello,
which is MCP601".
Thanks in Advance.
Karan
I think you have mixed up between requierment of low impedance input with anti-aliasing . Here MCP601 is a op-amp which will provide low impedance to the ADC input.
ADC MCP3202 and Op-amp
Thanks for reply..
Do i need of Op-amp MCP601 while using ADC for measuring high voltages.
Karan
