vanika
Newbie level 2
Hello !
My problem is to run Triple Mode, and generally want a detailed understanding of its boundary opportunities, see what you can squeeze out of this module, to build some graphics of his work, etc.
Actually, the result is the simultaneous operation of all three ADC, but in the data register Multi Mode CDR can be observed only zeros...
This result is obtained when the input sine wave has a frequency of about 7 kHz. It seems to me that I overlooked in the field sample rate.
Correct if I'm wrong
Code dot - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 // setup adc 1 ADC1->CR2 |= ADC_CR2_ADON; // on АЦП 1 ADC1->CR2 |= ADC_CR2_CONT ; // Continuos mode ADC1->SQR3 |= ADC_SQR3_SQ1_0; // select channel 1 for adc 1 (РА1) ADC1->CR1 &= ~ADC_CR1_RES; // setup resolution ADC1->SQR1 &= ~ADC_SQR1_L; ADC1->CR2 &= ~ADC_CR2_ALIGN; // allign 'right' ADC1->CR2 &= ~ADC_CR2_EXTEN; //ADC1->CR2 |= ADC_CR2_SWSTART; // run! // setup adc 2 ADC2->CR2 |= ADC_CR2_ADON; // on ADC 2 ADC2->CR2 |= ADC_CR2_CONT ; // Continuos mode ADC2->SQR3 |= ADC_SQR3_SQ1_0; // select channel 1 for adc 2 (РА1) ADC2->CR1 &= ~ADC_CR1_RES; // setup resolution ADC2->SQR1 &= ~ADC_SQR1_L; ADC2->CR2 &= ~ADC_CR2_ALIGN; // allign 'right' ADC2->CR2 &= ~ADC_CR2_EXTEN; // //ADC2->CR2 |= ADC_CR2_SWSTART; // run! // setup adc 3 ADC3->CR2 |= ADC_CR2_ADON; // on ADC 3 ADC3->CR2 |= ADC_CR2_CONT ; // Continuos mode ADC3->SQR3 |= ADC_SQR3_SQ1_0; // select channel 1 for adc 3 (РА1) ADC3->CR1 &= ~ADC_CR1_RES; // setup resolution ADC3->SQR1 &= ~ADC_SQR1_L; ADC3->CR2 &= ~ADC_CR2_ALIGN; // allign 'right' ADC3->CR2 &= ~ADC_CR2_EXTEN; // //ADC3->CR2 |= ADC_CR2_SWSTART; // run! // Triple MODE ADC->CCR = 0x17; // Triple MODE ADC1->CR2 |= ADC_CR2_SWSTART; // RUN!
