icd
Junior Member level 3
i am working on a data acquisition system and i need to convert the analog data that is coming from the photo diode to digital using large number of ADCs. i am usnig 8-Channel ADC ( 8 inputs and 8 outputs). the ADC processes 18 samples per pulse each sample 12 bits. my question is there any ADC with 16-channels ( 16 inputs - 16 outputs), with high performance can i use to decrease the number of ADCs that are used? i found 16-channel inputs and 1 channel output (parallel input serial output).
thanks
thanks
