AD9288 is not working in Proteus
majd-ghadab
Newbie level 5
Newbie level 5
Hello everyone,
can someone help me please, why the simulation of AD9288 is not working in proteus.
Thanks a lot
  • ADC.zip
In real world you need:
* VCC capacitors
* capacitors at analog inputs (my recommendation)
* to connect all inputs (even the unused ones) with useful signals
* current limiting resistors at the LEDs
We can't verify ENC frequency, nor the voltage levels.
Try "normal operation mode", see Table4.
Common mode input voltage range is off specification.
Differential mode input voltage range is off specification.
Klaus
Hello, i have tried to connect all outputs and used the normal mode but still no luck!
  • ADCEdited.zip
There is no code on this attachment, of if there is somehow embeeded in the project file, not everybody has this program.
