The problem is that in simulation I don't have the possibility to go up much with the input frequency and actually I don't know the behavior beyond 100Mhz.
My answer is: I can't give a suitable answer, because I dont have enough experience in this range of frequency.Why doesn't anyone answer every time I explain what I want to do @FvM @KlausST ?
A single filter stage is probably insufficient for a high gain RF amplifier. A popular scheme is a filter chain with increasing attenuation for the most sensitive stage. Suggest to start with lower gain, e.g. 2 stages.I have not foreseen any filter inductance (it is a good advice in fact) I have to put one on each single stage or one for all four the stages on the outputs of the regulators?).
4) 100mV = 1Volt
a bandwidth of about 500Mhz
first state with a limited Gain
about sziklai pairs configuration it seems to me very similar to Darlington transistors but which I didn't know about.
