AD8017 connecting output to negative input
klick
Junior Member level 1
AD8017
I use AD8017 to drive 100 Ohm balanced line.
I use AD8017 like inverter amplifier with gain=3
The circuit work wery well..
If i connect the OUT of AD8017 whit negative input(voltage follower) and i connect the positive input at VCC/2 the IC burns...(the AD8017 is connect at single power VCC= 12V)
I d'ont understand whi......
Thanks
Re: AD8017
The AD8017 as a CFA (current-feeedback amp) needs a minimum resistance in the feedback path.
That means it is not allowed to connect directly the output with the inv. input.
Look at the data sheet!!!
AD8017
Becouse its a currentfeadback amp? you can not all typical circuit techniques 1:1 or simple apply...
Check pls datasheest fig. 38 & 39.
K..
Re: AD8017
thanks...
but, where are the fig. 38 and 39 on the datasheet????
there are only 12 figures...
If i use the AD8017 whit gain=2 whit 2k2 resistance in the feedbak to drive 100 Ohm balanced line, there are problem????
thanks..
Re: AD8017
With a CFB amplifier, the output to inverting input resistor sets the loop gain, almost independantly of the divider ratio. For
maximum bandwith, you should use 620 ohms as suggested in the datasheet. With 2k2, the bandwidth is reduced to
about a third.
Re: AD8017
thanks
i understand...
but, there is anoter operational like AD8017 but with wider band at gain =4 to drive balanced line ??
Re: AD8017
Google makes wonder
alldatasheet.com has an old Rev. A, ADI's recent version is Rev. C and has new numbering of diagrams.
To select a possibly better suited amplifier, you should tell your specification (intended circuit, output voltage, bandwidth,
intended input impedance) . You didn't yet.
Re: AD8017
klick said:
...but, there is anoter operational like AD8017 but with wider band at gain =4 to drive balanced line ??
Whay is it another as AD8017 pls?
I think your problem was the biasing to 50% Vcc & not some gain factor?
It must go on principal settings first, as other ppls sayd too: its a CFA, the schema is at fig. 6 to see/find & the discussed circuit at fig. 7_or do you need a guidance to your mouse pls?
An adult person must do some advanced intelligence apply and check for solutions self too, if something isnt 100% given in the hands_sorry, is to write a new text is simpler as think over subject & check the producers home side for data? That can you alone believ...
Good luck & progress!
K.
