fala
Full Member level 5
Hello, I have two questions concerning ad676(here is datasheet https://www.analog.com/UploadedFiles/Data_Sheets/108732642ad677.pdf). as a matter of fact I've been trying hard to get full resolution(16 bit) of this device but not much success.
1- in the datasheet it has been noted that AGND and DGND should be connected at one point preferably at the ad676. I read somewhere else that's because if a voltage difference between AGND and DGND exists it can damage the IC. but if AGND and DGND be connected at ad676 then the ground return path of both analog and digital are exactly commom and all the noises in digital section will be present in analog section. right? why datasheet has recommended such scheme? then what is the use of separate AGND and DGND if we connect them at ad676?
2-I have made a circuit that uses ad676. I have made all the recommendations of datasheet: a) I have used two different grounds connected at ad676. analog ground for reference ad587, analog sections and digital ground for microcontroller and digital ICs. b)I have decoupled power exactly as datasheet has recommended.
c)I have used double sided board but with extensive ground zones(known in prrotel as polygons. both sides of the board have big Analog ground zones near ad676. d)signals are brought with shielded wires. but I still have lots of noise. when I connect input to analog ground and analog ground sense I get about 6 LSB (+/-3 in 65535 range) fluctuation.(Sampling rate is about 1KS/sec).
I founded(may be I'm wrong) that analog ground sense is extremely sensetive factor when I connect ad676 input to an analog voltage in another board(via
sheilded wire) and also connect AGND sense to the ground of that board which of course has the same AGND with my ad676 board noise level considerably increases. environment noise is not a strong factor although all the boards are in a metal box that connected to AGND. I founded that if I turn on a fluorcent lamp in vicinity of boards noise level dose not change considerably!
I will appreciate any hint or help or answer to any of my questions. thanks alot.
