chandlerbing65nm
Member level 5
Hello folks,
I have a problem with CMRR testing in lab. I simulated the AD628 CMRR test circuit in LTSpice and Multisim and got the same result, but when I try it in the laboratory I get different output.
Here is the test circuit for the CMRR.
Vin1 = 10V, find Vout1?
Vin2 = -10V, find Vout2?
CMRR = (Vout1 - Vout2)/(delta Vin * System Gain)
Here are my results in lab:
In LTSpice and Multisim, Vout1 when Vin = 10V should be negative like this below:
My expected CMRR result whould be within the limits: +/-178uV/V.
Even the known good units (Good 1-3) are failing, meaning there is something wrong.
I checked the connection multiple times and I'm sure there is nothing wrong with the set-up.
Here is the Datasheet of AD628:
https://www.analog.com/media/en/technical-documentation/data-sheets/AD628.pdf
