Ad Hoc/Wireless Mesh Network Simulation
suhanya
Newbie level 5
Newbie level 5
Where i can obtain source code (preferably MATLAB or C) for modeling an ad hoc or wireless mesh network?
I'd want to monitor the performance of a wireless mesh network under different methods of beamforming. Hence, it'll be helpful to have a basic wireless mesh network model for me to improvise on.
I've googled extensively in search of a basic source code for a ad hoc or wireless mesh, which can help me get started, but failed.
Any help would be greatly appreciated.
Hi I need some suggestion I am doing a project on RF-ID industry disaster basically the programing has on micro-controller but i want to run this project in MATLAB it possible.
hi freind's . i write this code's and run in nam(((---->cygwin in window 7 ))) ( code is copy here :C:\cygwin-ori\usr\local\ns-allinone-2.29\ns-2.29\aodv))
code's download from here :
set val(chan)           Channel/WirelessChannel        ;# channel type
set val(prop)           Propagation/TwoRayGround       ;# radio-propagation model
set val(netif)          Phy/WirelessPhy                ;# network interface type
set val(mac)            Mac/802_11                     ;# MAC type
set val(ifq)            Queue/DropTail/PriQueue        ;# interface queue type
set val(ll)             LL                             ;# link layer type
set val(ant)            Antenna/OmniAntenna            ;# antenna model
set val(ifqlen)         50                             ;# max packet in ifq
set val(nn)             2                              ;# number of mobilenodes
set val(rp)             AODV                           ;# routing protocol
set val(stop)           100                            ;# time of simulation end
set val(x)              500                            ;# X dimension of topography
set val(y)              400                            ;# Y dimension of topography
set ns_ [new Simulator]
set tracefd [open wireless2node1.tr w]
$ns_ trace-all $tracefd
set namtrace [open wireless2node1.nam w]
$ns_ namtrace-all-wireless $namtrace $val(x) $val(y)
set topo [new Topography]
$topo load_flatgrid $val(x) $val(y)
#create-god $val(nn)
set god_ [create-god $val(nn)]
# configure the nodes
$ns_ node-config -adhocRouting $val(rp) \
		-llType $val(ll) \
		-macType $val(mac) \
		-ifqType $val(ifq) \
		-ifqLen $val(ifqlen) \
		-antType $val(ant) \
		-propType $val(prop) \
		-phyType $val(netif) \
		-channelType [new $val(chan)] \
		-topoInstance $topo \
		-agentTrace ON \
		-routerTrace ON \
		-macTrace ON \
		-movementTrace OFF
for {set i 0} {$i < $val(nn) } {incr i} {
         set node_($i) [$ns_ node]
         $ns_ initial_node_pos $node_($i) 20.0
         $node_($i) random-motion 0
$node_(0) set X_ 5.0
$node_(0) set Y_ 10.0
$node_(0) set Z_ 0.0
$ns_  at 0.0 "$node_(0) setdest 5.0 10.0 0.0"
$node_(1) set X_ 400.0
$node_(1) set y_ 300.0
$node_(1) set Z_ 0.0
$ns_ at 1.0 "$node_(1) setdest 24.01 20.01 15.1"
$ns_  at 0.0 "$node_(1) setdest 400.0 300.0 0.0"
$ns_ at 2.0 "$node_(0) setdest 155.0 110.0 55.0"
$ns_ at 5.0 "$node_(1) setdest 105.0 110.0 21.0"
$ns_ at 10.0 "$node_(0) setdest 185.0 260.0 45.0"
$ns_ at 40.0 "$node_(0) setdest 105.0 140.0 33.0"
$ns_ at 45.0 "$node_(1) setdest 125.0 210.0 33.0"
$ns_ at 50.0 "$node_(0) setdest 115.0 230.0 60.0"
$ns_ at 100.0 "$node_(1) setdest 200.0 280.0 10.0"
$ns_ at 130.0 "$node_(0) setdest 250.0 380.0 22.0"
proc stop {} {
	global ns_ tracefd namtrace
	$ns_ flush-trace
	close $tracefd
	close $namtrace
	exit 0
set tcp [new Agent/TCP]
$ns_ attach-agent $node_(0) $tcp
set sink [new Agent/TCPSink]
$ns_ attach-agent $node_(1) $sink
set ftp [new Application/FTP]
$ftp attach-agent $tcp
$ns_ connect $tcp $sink
$ns_ at 0.0.050000 "$ftp start"
$ns_ at 150.0.050000 "stop"
puts "Starting Simulation for you.."
$ns_ run
and
set val(nn) 25 ;# number of mobilenodes
set val(y) 500 ;# Y dimension of topography
set val(cstop) 451 ;# time of connections end
set val(stop) 100.0 ;# time of simulation end
set val(t1) 0.0 ;
set val(t2) 0.0 ;
set val(cp)"scen-25-nodes"
set val(cc) "cbr"
####### Initialization
#######Create a ns simulator
#######Setup topography object
set god_[God instance]
source $val(cp)
#######Open the NS trace file
set tracefile [open out.tr w]
$ns_ trace-all $tracefile
#######Open the NAM trace file
set namfile [open out.nam w]
$ns_ namtrace-all $namfile
$ns_ namtrace-all-wireless $namfile $val(x) $val(y)
set chan [new $val(chan)];#Create wireless channel
####### Mobile node parameter setup
		 -llType $val(ll) \
		 -channelType $chan \
		 -agentTrace ON \
		 -routerTrace ON \
		 -macTrace ON \
		 -movementTrace ON
puts "Creating nodes..."
for {set i 0} {$i < $val(nn)} {incr i} {
$node_($i) random-motion 0 ;#######disable random motion
puts "Loading random movement pattern..."
set god_ [God instance]
source $val(cp)
####### CBR Connections generated by cbrgen
source $val(cc)
####### Define initial node position
$ns_ initial_node_pos $node_($i) 30
####### CBR connections stops
for {set i 0} {$i < 3 } {incr i} {
$ns_ at $val(cstop) "$cbr_($i) stop"
####### Tell all nodes when the simulation ends
$ns_ at $val(stop).000000001 "$node_($i) reset";
####### Termination
#######Define a 'finish' procedure
proc finish {} {
global ns tracefile namfile
$ns_ flush-trace
close $tracefile
close $namfile
exec nam out.nam &
exit 0
for {set i 0} {$i < $val(nn) } { incr i } {
$ns_ at $val(stop) "\$node_($i) reset"
$ns_ at $val(stop) "$ns_ nam-end-wireless $val(stop)"
$ns_ at $val(stop) "finish"
$ns_ at $val(stop) "puts \"done\" ; $ns_ halt"
$ns_ run
and code hsoft_project.tcl fronm this forum
but all of code's display one error :((why and how solution :)))
$ ns wireless4_1node.tcl
invalid command name "i>>?set"
while executing
"i>>?set val(prop) propagation/TwoRayGround "
(file "wireless4_1node.tcl" line1)
please help me for solution error .!!!!!!
thx
