rajaram04
Advanced Member level 3
perhaps AAD149 can deliver current of the order of 3 Amps while SK100 may not. perhaps the OP can try some better device like BD140 that could deliver at least 1Amp odd.Other than the lack of voltage as mvs sarma pointed out, the AD149 is a germanium device and known for it's high leakage current. Although it may work, the chances are the LEDs will never fully turn off.
Brian.
Rajaram, you are missing what we are teling you: If each LED takes say 3.7V, when you wire 5 of them in series it takes (3.7 x 5) = 18.5V to operate them. Unless you can increase the supply to about 20V you have no option but to reduce the number of LEDs. We are suggesting you use no more than 3 LEDs although 2 would be better and increase the number of chains of them, each with it's own series resistor to make up the total number you need.
Brian.
Please indicate the wattage of the LEDs used and the current you want to drive in for each chain. what ever, you need to have only 3 LEDs that too for a very short while before the battery drops to lower voltage. Even three are doubtful as the drop of three LEDs works around 11.1V dropping resistor should have margin depending on current need.
a generic formula can be used
I assume linear operation. forgetting the transistors and their need. I also indicate the formula for one series chain with n LEDS could be
I = [Vsupply-(n*Vf)]/Rs thus
Vsupply > (I*Rs)+(n*Vf)
Rs=[Vsupply-(n*Vf)]/I
Itotal would be i*x where x is number of such chains.
The BD140 is rated at 1.5A max collector current and 8W maximum dissipation.
I doubt your LEDs take that much, especially with 470 Ohm resistors in series with them so you should be OK in respect of it's maximum Ic rating. However, it will warm up and could overheat although I would say the risk is low. The power it will dissipate is the voltage across the emitter and collector multiplied by the current through it but without more information on the LEDs it's difficult to make a calculation.
The circuit isn't very well designed, apart from the LED voltage issues, when the first transistor turns off, it leaves the base of the second transistor floating. In practice, this could result in the LEDs still glowing slightly when they should be completely off.
Brian.
