glenhadlee
Newbie level 3
Below is the schematic with which I need help.
I want to calculate the following parameters using Spectre but am not sure how to go about doing it-
1.) Input common mode range
2.) Output resistance
3.) Differential gain
4.) Unity gain frequency
5.) Input referred thermal noise at 1 MHz
Transistors M1, M2, M3 and M4 have a W/L of 48u/240nm and transistors M5 and M6 have a W/L of 96um/240nm.
Based on my understanding, M6 and M5 are behaving as a current mirror and M6 is being biased to 100uA in saturation by the 100uA current source. M3 and M4 also form a current mirror and hence 50uA is flowing through each of them(M3 and M4). I need a Vgs-Vth=0.2V for transistors M1 and M2.
I have already extracted the unCox' value, Vth(0.4805V) and lambda for the transistors.
Based on Vgs-Vth=0.2 for M1 and M2, I have estimated the gm to be - gm = (2*Id)/(Vgs-Vth) ~= 0.5E-3 S (since Id has to be 50uA in saturation). I have also estimated the unity gain frequency - ft = (gm)/(2*pi*CL) ~= 39.79MHz
Can someone please provide some suggestions on how to go about calculating these results using Spectre? I want to simulate and obtain the results using Spectre.
