jonnybgood
Full Member level 4
In a tutorial I was asked to design an Active low pass filter DC-20Khz, 40dB/decade with a maximally flat response. I decided to go for a sallen key configuration with Butter-worth coefficients.
I chose an op amp suitable for audio applications: LT1028. My working is attached in pdf. My simulation shows that I got the correct values since I have a cut off (-3dB) at 20Khz and a roll of rate of 40dB/decade.
I derived the TF to a form suitable for drawing the bode plot by hand manually. I have a difficulty in drawing the bode plots because the values are not making sense. Am i doing something wrong in my working?
