auhunter
Newbie level 3
bp filter
I really need some help/suggestions. I am trying to construct a standard Multiple feedback active filter (MFB). I have used the forumlas, purchased several programs, used online calculators, to come up with the values to make an MFB bandpass filter. The latest attempt today I used an online calculator to get the resistor and capacitor values and I used the formulas to verify the same values are correct. However, when I build the circuit, it doesn't work. I've tried LMH6624, TL072, TLC2272 opamps. It doesn't seem to matter whatever I try, it doesn't seem to work correctly. In fact, they don't seem close to the paramters which are Fc=2100Hz, BW=300Hz, gain=1, utilizing 113KΩ input, 226KΩ feedback resistor, and 1164Ω for the 3rd resistor, the caps are equal at 4.7nF and 5V for Vcc. I've tried changing to other parameters with corresponding component values, filter topologies, etc but it doesn't seem to matter, I can't get one to work as it should. I'm using a Wavetek 288 signal generator and a Tektronix 2246 scope. I have been playing with this for quite some time but obviously I'm missing something because the results aren't coming close to the desired Fc and BW I'm trying for. Maybe someone here has suggestions as to what I might be doing wrong or what further I can try. Thanks for any help.
auhunter
auhunter
