rwp289
Newbie level 2
I work with cars and would like to add a warning light to fuel, oil pressure and water temperature circuits that have gauges but no warning lights. Most gauges signal via a chaging ohm value. For instance a fuel level gauge will read full at 100 ohms and empty at 10 ohms.
I would like to know if there is a resistor, diode, etc. that could be used to read the ohm value and "turn on" or "turn off" based upon an ohm value. In the case of the fuel gauge example, say at 20 ohms. Then I could add light or LED as a warning without the need for an additional sending unit or sensor.
Ideas?
Thanks
Ideas?
Thanks
