sabu31
Advanced Member level 1
- Joined
- Jan 28, 2011
- Messages
- 468
- Helped
- 12
- Reputation
- 24
- Reaction score
- 13
- Trophy points
- 1,298
- Activity points
- 5,370
Dear All,
I want to measrure AC voltage and current for an energy monitoring project. I am using differential amplifier configuration for sensing the voltages. However, i am getting error of more than 1 %. The voltage range is between 110V -250V RMS. The opamp used is MCP6022. Similar issue I am facing with Current. The current range is maximum of 200A and a CT (200/5) is used. The accuracy at lower currents is poor. And I need to get at least 1% accuracy. The sensing resistors used is having 1% tolerance.
WHat is the best approach and any references for the same.
