Accumulation varactor layout
mazelk
Full Member level 1
COLOMBIA
varactor layout
Hi...
How can I fix AMOS (accumulation MOS) - varactor's variables design to reach a minimun and maximun capacitance ?
How can I layout this device ?
I heard about split layout varactor into "rows" and "columns". Why ?
Best Regards
accumulation varactor
it is more like an analog circuit design.
pay attention to that the body contact to SD. This is to say,
SBD contact together.
And make sure Vgs<<Vth
mos accumulation varactor design
use of accumulation capacitance
Hi:
The maximum and minimum value of A-MOS could be determined by performing S-Parameter analysis for a given dimension. The imaginary portion is proportional to the capacitance of the A-MOS, for a given Vc.
The purpose of splitting the layout into number of rows and columns is to reduce the gate resistance of the varactor, due to its significant contribution to phase noise. Hope this helps
Rgds
varactor layout and quality factor
Modifying geometry, only change max. and min. capacitance values, also quality factor.
does exists any way to change C-V slope for accumulation varactor ??
I want to decrease its slope, because the gain of linear region is so high, and very small signal would be enough to change capacitance a lot, maybe undesirabilly.
accumulation mos
To reduce CV slope, paralell some fixed capacitor to varactor, but the tuning range of capacitance will be reduced also. Sweep the the length and width of one finger varactor may help you to findout a good area for it, also the bias voltage of source drain has effect on the tuning curve
Reactions: eli631
    eli631
