Access to Replay Protected Memory Block (RPMB) in eMMC 4.4 card
jituelect
Newbie level 5
Newbie level 5
India
I have a S3C2443 board (which supports eMMC) and a NAND flash chip, compliant with eMMC 4.4.
I am able to perform other operation like boot, read/write, WP, lock/unlock, erase etc.
I am trying to access the RPMB area but always getting the general failure.
(I have not set the key, as it was also giving general failure)
steps I took to access RPMB.
# Set R/W access to RPMB by writing 0x03 to byte 179 in EXT_CSD.
# Create a RPMB frame(512 bytes) for reading counter value.
//writing the read counter request
# Issue CMD23 with reliable write & blk count=1.
# Issue CMD25.
//writing the result register read request
# Create RPMB frame for "result register read".
# Issue CMD23 with blk count=1.
# Issue CMD25.
// reading the register
# Issue CMD18.
The structure for RPMB frame, I am using is
// RPMB data
#define RPMB_FRAME_SIZE (512)
#define RPMB_STUFF_SIZE (196)
#define RPMB_KEY_MAC_SIZE (32)
#define RPMB_DATA_SIZE (256)
#define RPMB_NONCE_SIZE (16)
#define RPMB_WCOUNT_SIZE (4)
#define RPMB_ADDR_SIZE (2)
#define RPMB_BCOUNT_SIZE (2)
#define RPMB_RESULT_SIZE (2)
#define RPMB_REQ_RESP_SIZE (2)
typedef struct {
unsigned char stuff[RPMB_STUFF_SIZE];
unsigned char key_mac[RPMB_KEY_MAC_SIZE];
unsigned char data[RPMB_DATA_SIZE];
unsigned char nonce[RPMB_NONCE_SIZE];
unsigned int wcounter;
unsigned short addr;
unsigned short bcount;
unsigned short result;
unsigned short req_resp;
} RPMB_FRAME;
Am I missing something?
Any help is greatly appreciated.
TIA
Hello,
I am trying to get the RPMB. I am a beginner though.
Can you please let me know if were successful in doing this ? if so, please post sample code and details on generating the RPMB data frame.
IF you wish, You may personally post it to vpse at yahoo dot com.
Thanks,
Prakash
Hello,
Thanks,
Prakash
HI I need some help in programming eMMC. can you please tell me what is this Relative card address?
suppose if have to write to a particular address from one host. and read from another host from the same address. how is it done with RCA?
Thanks
Sidharth
