acceptable side lobes and back lobe levels in derective antennas
noorulain069
Newbie level 3
Newbie level 3
hello
plz tell me what should be the acceptable back lobe and side lobe level in dB scale,if my main lobe is at 15 dB?
noor
there isn't any general value for that.
it depends on the requirements of your application (if you are a user) or the specification asked by a client (if you are a manufacturer)
Antenna stray lobes depend on desired interference levels required for directivity reception or transmission.
15 dBi peak with 0dBi lobes may be adequate for some applications but for a RADAR signal it might need to be -40dBi depending on dynamic range of signals.
thank you so much...
stay blessed... :)
