AC switching
Druggan
Newbie
Newbie level 1
I have two inductive loads C1 & C2. While C1 is passively connected to an A/C outlet (230 V, 50 Hz), C2 will be switched on demand as per Figures 1 & 2, hereto referred as State 1 and State 2. A suitable signal may be used to trigger the switch gates, say -5 V for State 1 and +5 V for State 2 (to be determined by the designer). The switching frequency may be from zero to say 400 Hz. The maximum operating amperage is 2 A.
  • Motor operation with switched field-Model.pdf
LaTeX Commands Quick-Menu:
