AC switching circuit design
tanzil_dhk
Full Member level 1
can anyone help me with an ac switching circuit design.i want to control light and fan using a microcontroller. are DIAC and TRIAC must for this type of circuit??
Use off-the-shelf solid-state relays (incorporate zero-crossing detector, optocoupler and triac) which can be controlled directly from microcontroller pins, or use discrete components such as optocouplers (MOC-series, for instance) and triacs to build one .. see picture below ..
Regards,
IanP
you can use the triac for dimmer lamp, optocouplers if you want to separated the control circuit and load circuit.
