AC power down from 220v to 5v
hossam abdo
Full Member level 2
Alexandria, Egypt, Egypt
Dear all
Can i down the AC voltage from 220v to 10 volt without transformer,
Is there any device make this function?
thanks in advance.
Transformer-less PS:
ww1.microchip.com/downloads/en/appnotes/00954A.pdf
:wink:
IanP
Reactions: dselec
    dselec
@hossam abdo
What is important is the amount of output power required to be generate by this power supply. In order to choose the best solution you need to provide the necessary current for the 10V output.
Yes power power current ?
what is the load ? is isolated
talking cheap u can do that with a 250vac 1uf capacitor 50k resistor and 5.1 zener.
DO NOT DO WHAT I SAY IF ANY PART NEEDING ISOLATION, TELL US EXACTLY WHAT U ARE DOING.
also see transformerless power supply
posted by Ianp
Are you trying for an AC or DC output?
what is the vac?
I want to design a variable Dc power supply but without transformer.
thanks to all for your interest.
Maybe u mean a variac.
what is your voltage range and current range ?
