bmandl
Full Member level 4
Hello.
I am planning to build an 12 channel DMX dimmer. Right now I am figuring out the power part of the project. After some research, I decided that I will try to make trailing edge AC phase cut dimmer with an IGBTs. While googling for solutions, I came across this dedicated IC: FL5150. It seems, that it would be a quite convenient solution, with everything integrated in IC (avoiding zero-cross detection circuit, no MCU programming for off-delay timing -> just outputing an analog signal to this IC).
The problem is, I cannot find any distributors in Europe for this IC. Farnell has just 60Hz version of it, which I can not use, since we have 50Hz mains voltage. Does anyone know of any alternative, or where could I get this IC from Europe (we have quite expensive import taxes from USA).
Thank you for any help.
