nramesh
Junior Member level 1
I wanted to add one more feature to my present design.But i am not sure whether such feature is feasible ... I need your support in the regarding...
My design application is similar to remote power switch... Load can be any appliance (up to 2-5 A current rating.) I am using SSR relay to switch on/off the load. Prototype works fine without any issues. But there is one practical issue ( here in india ). Sometimes live and neutral gets swapped in wiring...
I have seen many appliances like TV supports such live-neutral swapping.
Is there any circuit/devices present to support such feature?
I would like to address following concerns...
1.There should not be any damage to appliance.
2.There should not be any damage to my internal AC- DC converter section ( which is the power source for micro controller section).
3.Even in worst possible failure case, there should not be any fireworks...
Looking forward to your valuable response...
Regards,
Ramesh
Regards,
Ramesh
