soumen21
Member level 5
Dear Experts,
The circuit shown above is for AC input working up to 132VAC. Turn ON voltage is 74VAC. Input resistance is 6mA. This is a 16-channel 120VAC module
I wanted to make it work for 16 channels, 240VAC. If I reduce the input current to 3mA, I guess the heat dissipation will be less.
I propose to make the following changes to the above circuit.
C37 changes to 0.68uF 630V
R83 translated to two resistors in series equivalent to 771K
R67 as is i.e., 1K
C21 changed to 1UF 50V Y5V 1206
R51 to 267Ohms
No change in U5 i.e., PS2505L-4-A
R20 changed to 12.1K
Do you see any challenges for the circuit to work?
R67 as is i.e., 1K
R51 to 267Ohms
