munu
Newbie
I read a bunch of posts but I am still a bit confused about grounding. Lets say you have:
It is my understanding that in order to have proper communication between the two devices (#1 and #3) they must have their DC ground on the same level (unless you use some differential voltage protocol). You also should put the AC ground/neutral on the same level as DC 0V. So basically you have AC ground from device #1, AC neutral from device #1, DC 0V from device #1, AC ground from device #2, AC neutral from device #2 and DC 0V from device #2 all connected together.
But doesn't that create hazards because if device #1 is on a different level than device #2 you can have current flow across the communication channel? Also wouldn't ground for one device be (slightly) different than ground on the other side? Maybe if it is just some 100mV it doesn't matter.
- A DC device that received data. The communication could be a serial connection, a CameraLink connection, etc.
- An AC/DC power supply that provides the above device in point #1 DC power
- Some device anywhere from a few feet to lets say 100 feet away that tries to communicate with that device in bullet point #1.
- The above device in bullet point #3 is powered by an AC outlet (possibly some 100' away from #1) but runs on DC (basically a computer)
