sruthisreenivas2009@gmail
Newbie
How to improve AC input power measurement accuracy for DC output loads below 10 % of maximum output power of AC/DC power supply units?
Thank you for your reply. I was thinking with this very low load we will have more power loss (reactive power) than actual power. Then we may need to consider the power factor for the input power. I need to understand more on details like this. What all the factors will affect the accuracy of the measurement during this low loads below 10% of max output power. Let the max output power be 1320 W or 360 W.simply loop the AC wires thru the current sensor twice or more to up the current sensitivity ( obviously won't work with a resistive shunt )
I need to measure the real input power and I am thinking of Power meter IC as an option. Since I need those values for later analysis. Yes, the power supply has power factor correction.The question isn't clear. Are you measuring input current or real input power? In the latter case you need a power meter, power analyzer or a digital oscilloscope able to calculate real power from voltage and current measurements.
Does the power supply perform power factor correction?
