SG61-addict
Junior Member level 1
Hello,
I have a complex project :
- RF board
- BMS board + Li-ion pack
- CPU board based on a rpi compute module
- Large LCD screen with capacitive touch panel (this one)
All theses items are inside an aluminium box.
I am using a 230V to 24V/2.5A AC/DC power supply to charge the battery.
The AC/DC is a meanwell GST60A-24 : datasheet
The datasheet indicates a maximum leakage current of 0.75mA under 240V.
In practice :
- When touching the aluminium box, I can feel a non-dangerous but uncomfortable current.
- The DMM measures a 75Vac between the box and the ground, and 250µA leaks.
- Through the human body, the leaks is limited to 100µA (65-70Vac).
- The worse thing is that the capacitive touch screen works very bad when the power supply is connected.
I have found 20-30 AC/DC power supplies from meanwell, power pax, XP power, CUI... all have a 250 to 750µA leakage current.
My main objective is to get the touch screen working in all conditions. Should I use another PSU, or add some filtering somewhere ?
Thank you,
Regards
- RF board
In practice :
Thank you,
Regards
