dipumon
Newbie level 3
Hello,
I am trying to measure ac current flowing through an ac motor using hall effect current sensor ACS712 with maximum current rating of 5A.
The sensor is interfaced to the raspberry pi through an ADC in series with the motor.
The problem I am facing is everytime I get 2.5V from the output pin(Vo) of the sensor. The value never changes even when I connect the sensor or switch it on/off.
The digital reading from the ADC is also shown as 510-514.
I tried replacing the IC, but got the same result.
Can anyone guide me in measuring the AC current using ACS712 or suggest any other sensor for the same.
